1 - 20 of 29 Posts
customer wants mold resistant sheetrock in basement but he does not want greenboard or duroc. what should i use its gonna get taped and painted. Do they make a mold resistant board .
Contractor of the Month
I don't know toss' all about drywall but 8 months ago I finished a job in a reno of a 9000 square foot house that suffered sever mold problems. Part of the house used regular drywall which was all torn out and replaced, the rest had a shiny foil back drywall which the mold didn't touch.
Be sure to use mold resistant tape as well as wallboard. The Corning product works great and I spray the interior spaces with a borate and anti-freeze mix (glycol) that stops mold, dry rot, and even termites in their tracks, should a leak develop.
Were in hell did you get that idea?
You will probably be getting more
like it, since the anti-freeze is killing
more brain cells all of the time.
I have an idea.
Call your Board of Health, and
share this clever trick with them. :clap:
Sheet Rock
I would use a good paint or sealer instead of purchasing mold resistant sheet rock which can be expensive, not to mention once it is attached via screws or nails, the mold resistant surface is no longer covering the entire sheet, thus it is still suseptible to mold.
Pompass Ass
you should go with a MR board, the denshield will cost more.
MR is greenboard, it is moisture resistant, not Mold resistant, not even sure if MR is available as it has been replaced with XP (barney board) it is Mold resistant as well as Moisture resistant.
The reason denshield will cost more than MR, is because it is a better product.
You might want to rethink this.
1 - 20 of 29 Posts
