1 - 13 of 13 Posts
· Paul
Anyone have a suggestion on where to find a decent moisture meter at a decent price? Something like the tramex cme4... maybe someone has an extra or somebody going out of business, i hate to spend boku bucks for something i will use once or twice a year.
I would hate to spend ANY money on a tool whose only function is accuracy, if it ain't got it. Without it it is just a plastic square with lights and numbers....a $2 calculator will give you that.
It doesn't matter if you use it twice or a hundred times a year, its gotta be accurate.
Cheap out on some trowels or grout floats if you must, but not a piece of measuring equipment. Just my .02
· Knowledge Factory
Your not alone.
That thinking keeps the wood flooring failure investigators busy, doing inspections. I call it "job security"
That $400 meter, will save you $40,000. Pay now, or pay later.
I've had good luck on both craigslist and ebay,,, got a Mini DXC Ligno, with calibration tool included for 225. That was on ebay,,, what are your needs, I inspect hardwood floor failures
I need a meter to read concrete and wood. I am in the planning stage of hardwood over concrete, now there is existing 3/4 real hardwood on 1/3 of the floor now, it is 4 years old with no cupping or problems yet. I have a meeting with the customer on thursday, i will suggest engineered and go over the pros and cons of each over concrete. In the mean time i would like to acquire a meter to handle the 2-3 hardwood jobs i receive a year. I have checked ebay and craigslist both with no luck, only cheapo manufacturers on ebay and nothing in the area on CL. So i am here taking my chances that someone may have an extra or one they will no longer need.
Meter
Wow, on concrete, no cupping,,, lucky consumer. I like the Pin-type for hardwood and meters on concrete are less than accurate. I wrote an article regarding electronic meters on concrete and submitted to Ron Smith @ Wagner meter co. He said I was spot on in regards to inaccurate meters on concrete and for that matter nonintrusive meters on wood. I use the insitu probes on concrete now and my pin-meter on wood. I go to court alot and find the nonintrusive meters easily discounted. Insitu measures interior relative humidity which is much more accurate. If you email me I can send you the article in a PDF format. [email protected]
I like the engineered on concrete because the pre-finished warranty on floors like Mirage and Anderson take you, (the installer), out of the loop on finish complaints for up to 25 years
Meter
That being said FOLLOW the recommendations of the manufacturer of the floor you eventually install in regards to pre-installation testing and document, (with witness), all procedures/tests done. If a sand and finish follow NWFA NOFMA guidelines. (leave a paper trail for future liability),,,
For concrete: Tramex + Calcium Chloride + document everything
In-situ probes are more $, but more revealing of what the moisture content of the slab really is. I believe they will be required by manufacturers in the near future. If you can get get one of those on the cheap, I say get it.
1 - 13 of 13 Posts
