Benny, I thought todd was nuts when he said he was having problems, but yesterday it hapened to me. I stopped to blow down and as soon as I turned of the air to the meter valve off, the nozzle started to blow air.??
turn the air back on to the valve, it would stop.
I sat of over 30 mins, turning on and off and every time it failed.
Its a normally closed valve. and with the air off to it should stay shut. but some how the back psi is turning it on.
Todd and I both have new pots so wair and tear is not an issue?
Your set up is just like the one I used for over 10 years, This has me stumpped.
I would chalk it up to cold weather, but todd is in florada and it happened to him?
Benny, do you have a pressure regulater before the lines?
I've been doing this for year's Dyer and have never had a issue. Don't see how it could overide the air to the remote. Here is a picture of my set-up. From where my 1/4" line goes to my valve I installed a 1/4" ball valve going to each Grit Valve. Like I said, I have done this for years and never a problem and this is the first I have heard of it happening.
