Check out the video
_________________
[emoji631][emoji631]
_________________
What a waste of space :w00t:
Looks good but that wouldnt work for me. I was cleaning out my ridgid cases today.![]()
Mike.
_______________
[emoji631] [emoji631]
I've stood on mine. I keep my feet away from the center as much as possible. It's IP65 rated for weather. But it's not rated to be free from locking up from ice. Maybe make a nice fitted cover for it.
That little drill box is a nice kit with the molded plastic dropped in. One thing I’m noticing is that you cannot overfill the bins or the lid squares won’t drop in all the way. This also means you don’t have complete control of what bins go where. While the locking between boxes system works well, I don’t think it’s a perfect system.
I've stood in the middle of any of my pack out main three size boxes. And clear top ones only if cups are inside. I'm 250......ishMy backorder came in. 3 stack plus slim organizer.
Questions:
1. Had anyone had issues leaving this out in snow and ice? It seems like the way they lock together could become a big issue if you leave this thing out in your truck bed.
2. Can you use this as a stool? I mean, I know it says right on the lid not to. But, can you? The lid doesn't seem too heavy duty.
Any idea what the two holes in the center between mounted chargers are for? Looks like battery or tape measure or something of similar size.In the packout rolling base unit. Under the lid there are two holes that line up with the two holes for the rapid dual charger. Left or right side. It will fight with the tray if you need them on same side.
Pro tip.........careful the screw depth or you will poke through the lid.........don't ask how I know.![]()
I believe that's where you can install the Milwaukee "gps" puck that if your case is stolen and the thieves use the app........you can find it. (Hence why onekey has not done well)Any idea what the two holes in the center between mounted chargers are for? Looks like battery or tape measure or something of similar size.
