1 - 6 of 6 Posts
Hi, new to the forum.
Have noticed that there are variations in the ways some manufacturers mount the metering valve to the botom of the pressure vessel. Unlike the familiar 1 1/4 BSP socket. In particular I noticed one soda unit that has a d flange style mount ( round flat plate with 4 drilled holes and a 2 inch? outlet hole) Just wondering why they do it that way and are there any benefits in doing so? Do they run a pneumatic butterfly valve for material shutoff, similar to much larger industrial pressure vessels?
cheers
Trial and Error Opperator
"The system that I saw with this system is the Chesapeak soda system.
Anyone had experience with these? "
I own one, works great.
Chessie Clean, (Blast Equipment & Service)
is on here sometimes. He knows them well,
would be worth a phone call for him to explain to you.
the 4 bolt on the bottom is for acess to the end of the metering rod and nozzle.
the grit (soda) is opperated by a elec. ball valve.
have had mine of a long time with out fail.
1 - 6 of 6 Posts
