1 - 20 of 55 Posts
Can metal roofing ever be installed without using a transition flashing between the two different pitches and shouldn't the lower piece of roofing material be attached under the upper piece, with or without the transition flashing? I have seen the upper piece of roofing material under the lower piece. Seems like water would run right under where these two pieces meet.
wow! :clap:
reply
aegisroofing :I don't think they installed my metal roof improperly. I haven't been able to get up there to look at it. It appears from the ground that the bottom panel is on top of the top panel (the one with a pitch) I don' think these guys (Amish) would install these panels improperly. This is rental property but I still expect it to be done right.
Roof Concrete Floor Daylighting Road surface
Lower pitch skylight fully double lock seamed on every connection. Where seams meet other seams (such as at the hip or valley) they get laid down and seamed in. Also need to lay seams down to allow water to flow off the roof.
I'll just take a guess :laughing:
So water doesn't get in them.
No sh*t:laughing:, I've just always did it different .
I spend the time to slice the top sides and fold the sides in , then use the top piece to cap over. The seam looks continuous :thumbsup:
Not digging the smashed seam:no:
Everyone does it different I guess. The transition looks beautiful thou.
1 - 20 of 55 Posts
