It doesn't take much reading to see that there is a big stigma against mesh tape by a lot of people around here. I was just wondering why? For veneer plaster that's what we've been using on the joints for years and never had a problem and those jobs have been around for a long, long time with no problems. :blink:
The way I understand it all we're doing when we finish a wall (plaster/drywall) is make all the separate pieces of sheetrock effectively 1 large piece that moves together instead of independently. Whether you do that with paper, mesh, or a piece of wood behind your joint as long as they are all solidly attached and barring any major foundation movement how would the joint crack whatever you used? (Paper, mesh, drywall, or plaster?)
It may not be comparing apples to apples but in my opinion mesh taped plaster > paper taped drywall when it comes to joint strength. Now between mesh taped drywall and paper taped drywall I really don't know which is stronger but personally I don't feel that there would be a huge difference between the two. I prefer paper when doing drywall but mostly that’s because I feel it’s easier to work with, not necessarily stronger. (Personally I've never had any problem with meshed joints, never had any call backs, and I know a few other tapers who do it quite often and never heard any problems from them either.)
