A "Lil-Itty-Bitty-One" !!!!
6 Cylinder is as follows:
http://en.allexperts.com/q/Towing-Issues-1411/1998-Dodge-Dakota-towing-1.htm
i had a 97 ranger v6 and pulled a 16' car hauler loaded with wood, walk planks, truss jib, 1/4" steel work platform 12' long and 30" wide that fit on a rough terrain lift truck. i dont know how much it all weighed, but had to be a lot. that truck pulled a lot of weight. all pulled from my bumper
Yeah that trailer is prob a good 4000lbs with tools. Take a look at your max load rateings for your truck and take a look to see if your gonna be legal first. Im sure your truck will pull it but it mostly depends on terrain. If your in the flat lands then you will be fine. Def wont be winning any races though. Just make sure you change your truck ASAP as it will be pushing that little 4 banger to it's limit. As long as you aint hitting massive hills or mountains and your within your limits then give it a go.Right now the only truck I have is a 2001 4 Cylinder Dodge Dakota. I am purchasing an enclosed trailer and was hoping you would have some suggestions as to the size my truck can handle. I will probably purchase a larger truck in a year or so. My work is mostly remodeling and the trailer would be used mostly for tools. Whenever I have to haul a heavy load, I can borrow a truck or have it delivered. I would guess all my tools and supplies would weigh somewhere between 1,000-1,500 pounds but again that is a guess.
From reading other "trailer size" threads, I believe I would be happiest with a 7x14 but didn't know if I had a little engine that could or couldn't. Also the majority of my driving will be about 10 miles round trip and no major hills.
Any advice is appreciated.
Thanks
Not sure what the max load of a trailer that size is but my 14 is 7klb fully loaded so i guess a 16 loaded would be about 8klb so not to much for bumper pull. a lot of 1/2 tons are rated at 11k+ pounds so a ranger should be able to do 8klb. Prob not legal but it should be able to pull it.off the bumper?!?
