Its been awhile since I framed so I'm checking to make sure what I want to do is acceptable.
I'm framing a 24'wide x 22' deep garage. I need to keep over all ht. as low as possible. Customer will drywall ceiling. Rafters will span 24' width. (4/12 gable roof).Rafters will be 2x6. Ceiling joist will be 2x12 for drywall, no center beam. Would it be a bad thing if I ran joists perpendicular to rafters, use lookouts 16oc to hold gable walls. My thoughts are if joists run with rafters the roof cut on joist would take away all my strength. If my head is in my
go easy on me. Thanks in advance for your input.
