1 - 10 of 10 Posts
Wood Craftsman
Brian,
I'm not familiar with setups for drives like yours, & I can't seem to get through to your Yasaka drive link.
All the stop/start switches I'm familiar with, are normally open, & close when you hit start. It's a small electro-magnetic contactor that holds the contacts closed, much like a starter/contactor. You press start to close contacts, press stop to break low voltage current to the magnetic contactor.
In answer to your question, you press to start, & press to stop.
Be sure to get the right voltage switch for the switch's contactor coil. I found a bunch of sites for that model start/stop on a Google search.
Joe
Contractor of the Month
I just looked up the switch part number, it should have NO/NC for both the stop and start. Use the NO Start to the RUN, and the NC Stop for the Stop.
Wood Craftsman
I need some help here guys....
I did a 2 wire system on my other Yaskawa drive on my lathe. This model I have is different.
You know what switch I have,....if you look at page 21 it shows the run/stop terminals but I am a little miffed at how to hook this up....:blink:
There is a bridge in the switch from #1 of the stop terminal to #3 of the start terminal.
I will upload a picture.....just give a few minutes ....
I appreciate the help cause B is thoroughly confused....:blink:
Thanks gents...;)
B,
Wood Craftsman
Discussion Starter · #9 ·
Well,
I posted this over at the mother ship and got an answer . What confused me was the terminal hookup on the GDP 303 .
The non-jumper run terminal goes to 1 on the VFD.
The jumpered stop terminal goes to 2 on the VFD.
The non-jumpered stop terminal goes to 9 on the VFD.
Parameter 00 must be set to 09.
Parameter 32 must be set to 00.
I'll be hooking this up this morning and hopefully when I hit that start button my 88D will come alive. The way I had it before I was using the digital display for the controller , it worked great but wanted a dedicated start/stop to control the drive. I made an entire new VFD enclosure for the saw and took the one that was on it and modified a few things and transferred it over to the Oliver 117-A. I really like VFD's (if you didn't know already.:laughing:) to control my machines.....it's mixing old machinery with new technology......and then there is the LED lighting,:clap:..
I can't help it..:rolleyes:...:laughing:
Thanks for the help guys.. I do appreciate it.:thumbsup:
B,
1 - 10 of 10 Posts
