1 - 17 of 17 Posts
im getting tires of my Milwaukee and Makita sawzalls that have the quick chuck....my blades keep poping out
who makes a good sawzall that uses a chuck key..i dont think milwaukee makes one anymore
as a plumber my sawzall gets wet and the quick chuck gets f'd up quickly...wd-40 helps, but after a while it stops working
I'm not sure if any of the brands still have the allen key. You may be better off looking around on ebay or craigslist for a couple older models in good shape.
I'm not a plumber so my sawzalls stay pretty dry, but I can definetly see where you are coming from. I have trouble with my Milwaukee cordless sawzall. Its a great saw in every other respect, but when the blade mechanism gets wet from cutting out old drains or working in the mud it needs wd-40 or it quits working.
ive owned many Milwaukee's....they all have had the issue.....
doesnt matter what the blade brand is
i took my Makita out of storage to start using instead....it has the same issue and its almost brand new
it does appear that no one makes a chuck key version...ill end up taking my Milwaukee in for a new chuck
i think my Makita did this from day 1....
Contractor
only problem I've ever experienced could be fixed w/ wd40. Gunk may have gotten into the mechanism and now allowing it to close completely, lubricant may clean it out and allow a better connection to the blade.
Contractor of the Month
My Dewalt is old enough that it uses a grub screw that I've lost and replaced a thousand times. My hilti has a twist release and it works well, but I rarely use my sawzall anymore.
I have a Milwaukee that's 20+ years old with a hex screw. Although the saw itself is excellent, I hate the blade holding mechanism. It loosens up way too fast. That was the single reason I bought a new one with the twist type blade holder.
Nail Driving Fool
Why not it was meant for just that purpose. WD-40 stands for water displacement #40 (for the 40th try)
WD40 is not a lube and although many people use it as one it will really gum things up overtime.
After you displace the water you should follow up with a good lube like Kroil or CLP.
1 - 17 of 17 Posts
