Buy some bananas
Buy some bananasGive him a nudge....:whistling:laughing:
I hope not also, but I have seen it twice before. Once where he mis-measured a room and the bathroom was 18" too small, mistake was blamed on the painters who were painting at the time of his measuring.I hope not. My client is not someone you want mad at you....this architect is on a slippery slope.
That is how every porch I have constructed was done. Although I am being told this is fine by other people who who have viewed the plan.I think the BCO series is completely the wrong choice for this application.
The lateral loads are around 830 lbs which might be correct but that is only in one direction, the direction parallel to the upward flanges. They are not rated for the other direction as far as I can see.
I think the posts are used as newels for railing also? Maybe not.
Anyway, I would suggest (if it where my deck) penetrating the deck with the posts and land them on the beam. Then blocking in both directions and 1/2" lags top and bottom to really lock them in place both directions.
that will be O.K. for the one set of posts but the others not in line with the beam should have their own footings that they bear on.
Andy.
It probably is then, I just have not seen it around here and I THINK it might not pass around here but have not done it that way so I don't really know.That is how every porch I have constructed was done. Although I am being told this is fine by other people who who have viewed the plan.
Seems unlikely to be OK with seismic rules, but it's allowed around here.It probably is then, I just have not seen it around here and I THINK it might not pass around here but have not done it that way so I don't really know.
Interesting.
Andy.
I actually like it and request that they make the plans as minimal as possible, that way I have a little wiggle room.I don't know why you are getting so bent out of shape about the drawings. You are just using up your energy. I take it you want to take his drawings, and then add some of your own ideas to make them a bit more structurally sound when it comes time to build. No court outside of Mogadishu would convict you of being in the wrong for that. Just build the f'in porch.
Except I'm not getting a permit with those plans, and I doubt the op is either.I don't know why you are getting so bent out of shape about the drawings. You are just using up your energy. I take it you want to take his drawings, and then add some of your own ideas to make them a bit more structurally sound when it comes time to build. No court outside of Mogadishu would convict you of being in the wrong for that. Just build the f'in porch.
I've received permits for much more complex projects with much less detailed plans. I guess it all depends on locale.Except I'm not getting a permit with those plans, and I doubt the op is either.
Minimal with code minimums is fine. But those plans will not pass plan review.
Exactly.I've received permits for much more complex projects with much less detailed plans. I guess it all depends on locale.
It's two things. It was made clear to the architect that the client wasn't sure what they wanted and were coming to him to help with design work. Then the plans he turned out were pretty bland and void of both structural details and aesthetic. I could have drawn what he drew.I don't know why you are getting so bent out of shape about the drawings. You are just using up your energy. I take it you want to take his drawings, and then add some of your own ideas to make them a bit more structurally sound when it comes time to build. No court outside of Mogadishu would convict you of being in the wrong for that. Just build the f'in porch.
Gotcha. I gather you helped them find the architect and helped handle the process. No good deed goes unpunishedIt's two things. It was made clear to the architect that the client wasn't sure what they wanted and were coming to him to help with design work. Then the plans he turned out were pretty bland and void of both structural details and aesthetic. I could have drawn what he drew.
