Lining up replacement drawer fronts.
494 views 27 replies 11 participants last post by  MarkJames
Looking for a better method to line up drawer fronts for replacement.
Had to replace several bad ones today (damaged mdf) , and I ended up rolling pieces of blue tape backwards to line them up and hold them until I could get them clamped and fastened.
Fortunately this time the drawers without the fronts were flush with the face frames. Sometimes that isn't the case.
#2 ·
All depends on what they are. I'm assuming overlay. Block of wood on the ground getting the drawer bank lower front aligned properly. 4 small pcs of double sided tape on the front of the drawer and then press the drawer in place. Secure it. Then another appropriate sized spacer for the next and then the next. Might want to make sure the spacers add up so the top of the bank is the same as the tops of the drawer fronts that go along the top of the cabinet. For the top of the cabinet fronts you use a spacer from the countertop and the double sided tape.
That's how I do it in the shop and it should work in the field.
#3 ·
Thanks. They were full overlay. Next time I'll do it with double-sided tape.
Pita side note: the screws that secured the fronts were amidst the dovetail joints. I had to pry them off with a 5-in-1 and a crowbar, then dremel off the screws. Fun. (Cabs were from N&it D@y C@binets)
#8 ·
I made fixtures to set drawer fronts. These are based/sized for our inset with under mount slides. We also have them for overlay and euro.
With these a drawer face can be set in less than a minute.
The drawer face is pushed against the lower stop 2 edges, the box is placed against the upper stop 2 sides.
These are used in the shop, I‘ve had to mock some up in the field. A couple of measurements some scrap material and you’re good to go.
No clue why the drawer box and face don’t line up properly…….
Tom
#17 ·
Just had to fix one of the HD cabinets that the face fell off.
Used my pinner to hold it while the glue set and I could drill the pulls, which is the only thing that keeps them on.
Short pins. A couple decided to eat thier spinach and blew through the front.
Can't tell if the lights are out or unless you look really, really close. That's my story and Im stickin' to it.
#15 · (Edited)
There's a variety of ways to do it... the simplest way onsite, is clamps and spacers...
Then just cut spacers to align, clamp, pre-drill and screw...
A jig we use for production that's easily adjustable (again, using spacers to align arm negates need for tape) is as follows, and makes quick work of it that can also be used onsite...
#20 ·
I am not going through all that for just a few drawer faces, the jig I posted is very fast. If I made all of the cabinets and was in the shop that would be fine but onsite in a finished kitchen no thanks. Just yesterday I had to work on 24 or so cabinet doors and 15 drawers and the housekeeper is cooking all sorts of crap. I was working around cooked carrots and cauliflower, they knew I was coming but that was not going to stop her.
