LEVELS OF GYPSUM BOARD FINISH
LEVEL 1 - Tape set in joint compound. Tool marks and ridges acceptable. Surface is free of excess joint compound.
Suggested use: Frequently specified in areas above ceilings, in attics, in areas where the assembly would generally be concealed, or in areas not normally open to public view. Some degree of sound and smoke control is provided. In some geographic areas, this level is referred to as "fire-taping". Tape and fastener heads need not be covered with joint compound.
_________________________________________________________________________________________________________________________________
LEVEL 2 - Tape embedded in joint compound and wiped with a joint knife, leaving a thin coat of compound over tape. Surface shall be covered by one separate coat of joint compound. Surface shall be free of excess joint compound. Tool marks and ridges acceptable. Joint compound applied over the body of the tape at the time of tape embedment shall be considered a separate coat of joint compound and shall satisfy the conditions of this level.
Suggested use: Specified where water-resistant gypsum backing board is used as a substrate for tile. May also be specified in garages, warehouse storage or other similar areas where surface appearance is not of primary concern.
LEVEL 3 - Taped as in level #2, then covered with two separate coats of joint compound. Joint compound shall be smooth and free of tool marks and ridges. Note: It is recommended that the prepared surface be coated with a drywall primer prior to the application of final finishes.
Suggested use: Typically specified in appearance areas which are to receive heavy or medium texture finishes before final painting, or where heavy-grade wall coverings are to be applied as the final decoration. This level of finish is not recommended where smooth painted surfaces, or light to medium weight wall coverings are specified.
LEVEL 4 - Taped as in level #2, then covered with three separate coats of joint compound. Joint compound shall be smooth and free of tool marks and ridges. Note: It is recommended that the prepared surface be coated with a drywall primer prior to the application of final finishes.
Suggested use: This level should be specified where flat paints, light textures or wall coverings are to be applied. In critical lighting areas, flat paints applied over light textures tend to reduce joint photographing. Gloss, semi-gloss and enamel paints are not recommended over this level of finish. The weight, texture and sheen level of wall coverings applied over this level of finish should be carefully evaluated. Joints and fasteners must be adequately concealed if the wall covering material is lightweight, contains limited pattern, has a gloss finish or any combination of these features is present. Un-backed vinyl wall-coverings are not recommended over this level of finish.
LEVEL 5 - Taped as in level #4. Surface shall be covered by three separate coats of joint compound. A thin skim coat of joint compound, or a material manufactured especially for this purpose, shall be applied to the entire surface. The surface shall be smooth and free of tool marks and ridges. Note: It is recommended that the prepared surface be coated with a drywall primer prior to the application of final finishes.
Suggested use: This level of finish is highly recommended where gloss, semi-gloss, enamel or non-textured flat paints are specified, or where severe lighting conditions occur. This highest quality finish is the most effective method to provide a uniform surface and minimize the possibility of joint photographing and of fasteners showing through the final decoration.
______________________________________________________________________________________________________________________________________________________________________________________________________________________
GLOSSARY
I had a finisher try to tell me that the reason why I can see speed bumps on a hallway (almost every joint was humped out bad) Is because the GC asked for a level 4 finish and If he wanted it 100% flat He should have paid for a level 5. I dont know about you guys but a level 4 still needs to be flat it just means you finish the joints, angles, and screws. A level 5 is a tight skim after you achieve a level 4 and sand it. The reason for a level 5 is not to flatten at all just to achieve a consistentcy of all mud so you cant see the difference in texture between the mudded portions of the wall and the paper face of the sheetrock. All in all a level 4 should be flat. Is this just a geographical thing or is it a universal concept?
