But that will cost more than the $200 they want to pay :laughing:
When can you start?I could get that done in a hour for about 30 bucks.
Mike.
_______________
Nothing gets done in an hour:laughing:I could get that done in a hour for about 30 bucks.
Mike.
_______________
These are the ones I use. You're using twice as many vs the other ones but there is zero need for basement access. They work very well. Fasten Master has something similar now that I would like to try.If interior access is limited,you could use this,however,the first one appears to be a more substantial connection.
https://www.youtube.com/watch?v=x7O7rBpmWwo
Dang Mike, you only charge $30/hr? :jester:
Me too. "sir, maam, your porch is failing here let me drive you to the bamk"I could get that done in a hour for about 30 bucks.
Mike.
_______________
And pull the hanger nails.How hard it is? Temp it up in 10 minutes, cut the old ledger out in 15 minutes, (three feet).
This is an interesting video discussing deck lateral loads and the hold downs required.
https://www.youtube.com/watch?v=nP6QzyxZgAw
Or just 2 blocks of 2 x ma material and a string.It would be interesting to see what it looks like to put a long straight edge right under the ledger along the wall there. If it was built that way I'd bet there is a big bump there. If the deck rim joist is straight I think it's safe to assume it was.
It's hard to find a straight string.Or just 2 blocks of 2 x ma material and a string.
