1 - 5 of 5 Posts
I have a friend who does commercial remodeling. He does lots of tile work in restaurants. One of his clients approached him about retiling a walkin freezer. Of course he said they could not turn it off.
I realize the inherent problems that seem to make this impossible, but I am not a flooring expert. So I turn to those who are, is there any way to do this?
I was involved in a large mud job when I was a teenager, they did two large coolers with Ceramic, I mostly just lugged and mixed the mud. I'd suspect that any technique that's approved for an outdoor setting in the North would be ok.
Flooring Guru
Porcelain, Porcelain, Porcelain, Porcelain, Porcelain
and more Porcelain
and more Porcelain
I imagine this should be used with Epoxy, Epoxy, Epoxy?
Would it be possible to work on small sections of the floor each night ( work window is from 3AM to 9AM) and use some sort of heat source to keep the adhesive and grout warm until they set?
I have heard the Laticrete commercial epoxy grout sets within hours if it is warm enough.
I spent some time reading and searching over at the JohnBridge forum. It is excellent but the only thing I found on this subject was that everyone there despises restraunt tile work. (understandably it would seem)
1 - 5 of 5 Posts
