Found this on another webite but i cant post the link cause im new
Indoor Use of Treated Wood
Pentachlorophenol treated wood should not be used in residential, industrial or commercial building interiors, except in laminated beams or building components that contact the ground and are subject to decay or insect infestation. When used for such purposes, pentachlorophenol treated wood must be covered with two coats of an appropriate sealer such as urethane, shellac, latex epoxy enamel or varnish.
The EPA has advised that creosote treated wood should not be used in residential building interiors. Creosote treated wood in interiors of industrial buildings should be used only for wood block flooring and for industrial building components that contact the soil and are subject ot decay or insect infestation. Such industrial application is acceptable, provided that two coats of an appropriate sealer are applied. For creosote treated wood block floaring, coal tar pitch and coal tar pitch emulsion are effective sealers. Urethane, epoxy and shellac are appropriate sealers for creosote treated wood when used other than as wood block flooring It is believed that limited interior uses of appropriately sealed pentachlorophenol and creosote treated wood will not cause unreasonable adverse effects to humans or the environment.
EPA has not advised against the interior use of arsenical treated wood because the arsenic air levels measured in homes constructed with this type of treated wood are not significantly different from background arsenic air levels when dust has been vacuumed from the wood surface. Therefore, wood that is pressure-treated with water-borned arsenical preservations may be used inside residences wtihout a sealer, providing that all machined sawdust is vacuumed from the wood surface.
Just thought this info might interest some of you.
