A regular client of mine has a building where the lobby walls are all painted fluted split block. They are considering laminating the walls with drywall but I was curious if anyone had any suggestions as to what type of adhesive should be used in this type of application. If it were a flat CMU wall I would probably use compound but being that there are so many gaps and the block is a split face therefore not a flat surface I wanted to know if anyone had any experience with a better adhesive choice.
Thanks!
Thanks!
