L
Loop
·Guest
I'm getting QuickStep 800 laminate flooring with the Unisound underlayment attached to the planks (10mm total). I'm also getting a 3mm cork underlayment. A vapor barrier will be installed too. The installation is in the kitchen/dining area and a total of ~180sq. feet. The kitchen has tiles which contain asbestos as well as the mastic and abatement is not an option (by choice + cost). The kitchen tiles are about 1 to 1.5mm thick, no more than 1/8", and the dining area is bare concrete so there is a small difference in level. Moisture does not seem to be a problem in SoCal.
Also, QuickStep has rather insistent (per their instructions) on using only QuickStep underlayments and I beleive the warranty is conditional on this clause. My reasoning is the planks already have the leveling underlayment (satisfying the warrant reqs) so a vapor barrier is all I need. The cork is for noise control and/or leveling.
Is there a problem with laying the cork first, then vapor barrier, and then laminate flooring? Is the 1/8" difference too much? Is the cork a dumb idea?
