1 - 20 of 24 Posts
· design build
OK, here's the problem. I have a recessed light in a shower. It has the proper trim ring and the install seemed to be done right. The light will only stay on for about 5 min. and stops working. After it cools down, it can be turned back on. It is between level 1 & 2 (no insulation). I'm the gc and my question is; do I call my electrician back to replace a faulty can or could something else be causing this?
If the fixture was installed improperly, or lamped improperly, and the thing turns off and on, then by all means you get sparky to fix it. If none of the above, and if the heat sensor cutout is faulty then the question is: Who provided the fixture in the first place? Was it the electrician or you or the homeowner? If sparky provided the cans, then get sparky back to furnish another one. His bid should have had that contingency covered. If you provided the can or the homeowner did, be prepared to hire sparky to come back and replace the can with a new one.
· design build
The electrician provided everything. My concern is having to redo the ceiling of the shower in order to install a new fixture. Does anyone know if there is a non invasive way to remove a new construction fixture and replace it with a remodel fixture. Maybe the parts can just be replaced without removing the housing.
· design build
Discussion Starter · #13 ·
The plumbing was my dumb azz idea. 3/4" supply lines to each location and home run to the basement. Insulate all the hot pipes so you dont wait too long for hot water. The aluminum tape is holding insulation on at the places it attaches to the framing. It all looks nasty because most of these home run pipes are going through this part of the ceiling. It only works within a normal day of activity. A few hours of non use and you have to wait 28 sec. for hot water. Awesome water pressure though. The tub can be filled in a matter of a few minutes. Next time I will make the tub the only one with this set up. I could always go back to installing a loop. This job did not have the budget for that.
I will see if the light fixture has any special requirements for the lamp before I call sparky.
· Builder/Remodeler
By the way, if the can light is faulty (unlikely), you can easily replace the whole sleeve which includes the heat cutoff. All new construction can lights are designed to be removable from below to access the j-box. There are usually two screws just inside the rim.
1 - 20 of 24 Posts
