1 - 12 of 12 Posts
Hey Guys just got numbers on these and pretty nicely priced. Any one use the Kolbe Vinyl? Any pros / cons. I have installed several of there metal clad and 0 issues all around just perfect except the empty pocket. Are they just like any other vinyl but with a high end brand? These would total replacement in brick to brick replacement or add framing to accommodate new construction fins.
No rants or raves just the facts on experience please.
Thanks
Yanni
citydeksinc.com
citypropertiesinc.net
I didn't know that Kolbe even offered an all vinyl line. After searching their website I was intrigued by the "Latitude" series. I couldn't find a downloadable PDF of a brochure from this series to really research them. No performance numbers or real details, very vague. I found one video that showed an interior view of factory mulled twin. Very nice looking.
Low profile mortised locks, lift handles as opposed to vinyl lift rails, glazing by Cardinal. Very nice stuff indeed. I'd like to know if they feature 3-point weatherstripping on the sashes, meeting rail non-metal sash reinforcement, foam filling, non-irrigating sills without stupid weep holes, type of balance system.
Being over in South Jersey right over the bridge from Delaware I threw in a Wilmington zip to see who offers Kolbe and all that came up close was West Chester, PA.
Maybe Homesealed will chime in? Looks like a solid product????
Same here it looks like a solid product. The rep is Steve at North American good guy. I've installed several kolbe window and doors but never vinyl.
The glass od is 7/8" argon low e they have the highest and latest energy ratings and up to date with all of there technology. I was looking at the single hung. My windows are just about 8ft h. I'm getting integrity number in the next day or two. I like them both. The kolbe a lil more because of the brick molding which save me time on the trim port of the install. Also getting the kolbe vinyl in black so I am a lil worried about long term fading were the integrity is fiberglass and a better uv protectant paint. kolbe vinyl can in 1/2 f the trimline. They are very nicely priced.
I got numbers from trimline metal clad almost 10grand. There od on the glass is 7/8 as well with super nice weather stripping seals. I've installed several of these as well and would comfortably rival marvin, kolbe and top shelf brand, but at 10k and 19 more to go I really don't want to be window rich.
Sounds like a some solid research. We don't get the request for such higher end products in my market place, thus I'm pretty much am a retrofit vinyl guy that is always stuck behind his siding brakes. I get jealous of such nicer wood and fiberglass projects.
Good luck. I'll have to check out the Kolbe line next time that I'm out that way towards West Chester. I like nicely designed metal lift handles on vinyl. OKNA's are well received by my homeowners. Schuco's, while not nearly as nice as OKNA's were nice back in the day. Never been a fan of the one's on the Simonton Impressions 9800, however I no long term experience with them
windows & siding
Some nice features but the performance is severely lacking. .30 U factor and .25cfm air infiltration on the double hung. You would be hard pressed to find a vinyl window with WORSE performance.
They have links to the tests right on the website.
I do like their wood products, but there is a reason IMO that the vinyl is not gaining much traction.
The performance numbers on the Kolbe vinyl are HORRIBLE ...
.30 ufactor and a .25 air leakage rate !!!!!
Kolbe may make a good wood window but their vinyl windows are low end.
Never buy a vinyl window from a company that makes wood windows; andersen and pella also make low end vinyl windows.
I like sunrise, okna, and soft lite. All excellent vinyl windows with some great performance numbers.
see that's what I'm looking for. I new there pricing was almost too good to be true.
I've done a lot of these in the past. My local window guy swears by them. There energy package is tight. Any thoughts?
http://www.nbpcorporation.com/Windows/Double_Hung/Crusader/index.php
Tech window guys can any thoughts on the marvin integrity? Full fiberglass framing.
Thank you.
windows & siding
Normally I'm not a fan of the all ultrex Integrity as IMO it is uglier than most good vinyl products and offers the poor performance of lower end vinyl. With a wood window ( as in the wood/ultrex) that is more acceptable as you are trading off performance for looks, but the all ultrex Integrity has few redeeming qualities. That said, one redeeming quality that it has is regarding painting. With a black exterior, the fg does inspire a little bit more confidence.
Wow, I knew that Homesealed would have info on them. Clearly, the window is built on appearance and not tight tolerances with better weatherstripping. Not a good choice for a northern climate in my opinion.
My outside rep over at J & L Building products was a rep with BF Rich previously. Quite a few loyal dealers around these parts with BF Rich. Like the Cabernets just wish they would redesign the sill.
Discussion Starter · #11 ·
Home stead. What energy and air leak numbers should I be looking at. This is for own house that has a lot of Windows. Also keeping this place for the long haul. What are best rated long lasting vinyl and metal clad out there. Also any thoughts on the Canadian PVC triple pane. I know a green architect that swears by them.
What numbers should I be looking for. Greatly appreciate the help . Thanks again
Discussion Starter · #12 · (Edited)
Guys I just found this link that breaks it down into a 2nd grade reading level. Punch in your details and there your list of windows and details.
I did one in Phila PA then Buffalo NY to see what the differences are. They came out exactly the same. It even gives you the brand and manufacturers.
http://efficientwindows.org
http://efficientwindows.org/new_selection1.php
1 - 12 of 12 Posts
