US Army Corps of Engineers says:
Beginning immediately after placement, and continuing for at least 7 days,
cure and protect all concrete from premature drying, extremes in
temperature, rapid temperature change, freezing, mechanical damage, and
exposure to rain or flowing water. Provide all materials and equipment
needed for adequate curing and protection at the site of the placement
prior to the start of concrete placement. Accomplish moisture preservation
of moisture for concrete surfaces not in contact with forms by one of the
following methods:
a. Continuous sprinkling or ponding.
b. Application of absorptive mats or fabrics kept continuously wet.
c. Application of sand kept continuously wet.
d. Application of impervious sheet material conforming to ASTM C 171.
e. Application of membrane-forming curing compound conforming to
ASTM C 309, Type 1-D, on surfaces permanently exposed to view.
Accomplish Type 2 on other surfaces in accordance with manufacturer's
instructions.
Accomplish the preservation of moisture for concrete surfaces placed
against wooden forms by keeping the forms continuously wet for 7 days . If
forms are removed prior to end of the required curing period, use other
curing methods for the balance of the curing period. Do not perform
protection removal if the temperature of the air in contact with the
cocrete may drop more than 60 degrees F within a 24 hour period.
