I am looking into buying a tracksaw to use for decks. I see a couple of uses right away. Trimming boards that are laid, cutting out boards for inlays, cutting stringers? And of course ripping any boards or riser fascia.
Does anyone use a track saw in their arsenal?
Get one. You won't be sorry (as long as you buy a decent one). I have the Makita. It works great for me.
They don't sell them here in my area. I've never seen another contractor here with one either. I don't think any contractor around me would even know what it is! :laughing:
But thanks to CT, I've been exposed to lots of things not available to me locally. Thank goodness for the internet.
and now I am spoiled. I now know I need a domino.
Do you clamp the track to the deck when you cut the ends off your deck boards? I'm not sure how you would attach the clamp. Also, do these saws have to be used with the track or can you cut with them free hand? I actually like the idea of the dust extractor more than the guide, it would be nice to make free hand cuts with it.It's faster, easier, and makes a much better cut then freehand. There is absolutely no reason not to get one for decks. It's great for cutting in a seam board or picture frame.
Yes, you can use a track saw for that, and depending on the neatness and accuracy required, it could be a good choice. However, the electronic motor control won't let you shove it through the stock the way you can with a bigfoot or other large circular - you have to slow down with a track saw and let it keep the RPMs up. When I'm cutting sheathing for walls, floors, or roofs, and there's a guy standing there waiting for the next sheet, I'd rather use a SkilSaw....
Has anyone ever used the 8" track saw to cut a bunk of plywood at full depth? I'm wondering if it's powerful enough, it would make a nice framing tool for cutting sheets of soffit plywood if it could.
