Joist length specs, avoiding bouncy floors
13K views 29 replies 19 participants last post by  3rd4thGEN
I am designing my next house to build, it will be a 30x40 rambler. I would like to put a girder down the center, giving me a little less than 15' on my joist span.
The span tables say that 15' is ok for 2x10 or 91/2" TJI. But, I'm concerned it may feel bouncy. I've only done up to 12'6" on a 2x10 before.
Thoughts?
#2 ·
If 15' is to the outside, your actual span is probably about 14' when you figure in the foundation wall, and the width of the beam. I think your floor would be ok with that span. I would go with a fir or pine joist and not spruce. If you have an island or a big tub you could add a few doublers.
#8 ·
He said he checked the tables. A 2x10 for a 10# dead and 40# live load @ 16" O.C. is good for 15'5" for SPF #2. Want to span that for bedrooms? You can now go to 17'2".
His issue is a concern for bouncing which is why I recommended framing 12" O.C.
#9 ·
The span tables used to be 16' for 2x10, 16" oc and 12' for a 2x8, 16" oc.
That was pretty standard. If you wanted to maximize, you built a 32' wide structure and used 16' 2x10's, or a 24' wide and used 12' 2x8's.
All of the homes in my neighborhood (1960's through the early 80's) are 24' wide and have 2x8 floor joists.
Why did the span tables change? Does anyone know?
Quality of lumber, fatter people, heavier live loads? Refrigerators are sure getting bigger, and people are sure getting heavier.
#12 ·
They have not changed in years except for recently SYP was reduced in span this year. I am finding the same numbers going back to the 2001 NDS for DF & SPF.
#15 ·
The issue with TJI's is that some areas require that the bottom be sheet rocked for fire protection due to how fast TJI's burn. It is to protect firefighters where there are no sprinklers in a residence.
#16 ·
Bounce and deflection are different things. Span tables are for deflection. Bounce in an otherwise structurally good floor usually becomes a problem with larger floor areas / support areas. The resonant frequency becomes close to footfalls when people walk. Think of the head of a drum. Big drum, head a little slack, and you get low frequencies. Small drum with head stretched tight gives high resonance frequencies.
I don't think I'd worry about it too much for the spans you're dealing with, but if you have a room getting up much above 15'X15', consider putting extra solid blocking in.
#18 ·
Span tables are mainly influenced by strength and to some degree on an arbitrary deflection ratio is some how representative of an engineering approach.
Feel and vibration is a factor that is "people-oriented" and no group would attempt put that kind of factor in a table, because it cannot be measured by any standard.
There is no question that bracing and blocking improves the "feel" because it spreads the load out somewhat to more joists or a slightly larger area.
Not that the reduced stresses have finally trickled down through the politics, the next question is how much difference is there in the real elasticity of the new growth lumber compared to decades of testing based on old growth wood. My guess is that it will take a couple of decades to get by the politics (associations and lumber producers with deep pockets) of standards and finally into a real code.
#24 ·
I heard a speaker at JLC live bring up the point of the feeling of a floor. If you have two sections of a floor, one with a longer span than the other, the feel of the floor will be different. The one with the longer span will have more bounce. He suggested adjusting the size or spacing of different length joists so they have the same deflection.
#27 ·
When you design a floor to code minimum, yes the floor bounces. I know from experience having to retrofit about a dozen floors my company framed. They were all designed to code but people kept complaining about their china cabinet rattling every time they walked across the living room. The fix for the future houses was to switch from 1 3/4" wide TJI's to 2 1/4" TJI's I think.
