Once the wood is up, the hard work is done. Even urethane adhesive scrapes up fairly easy with 4" stand-up scrapers.
Once the wood is up, the hard work is done. Even urethane adhesive scrapes up fairly easy with 4" stand-up scrapers.Looking at a job in an high rise condominium which involves removing glued engineered wood over glued cork. After using a mechanical floor scraper to remove bulk of flooring/cork should I just resolve to hand scrape the left over cork and glue out is there an easier way (less money)?
You do know there are 4' scrapers right? I buy mine at the supply shops for around $20. Sure as hell beats using a small one for big areas.The fact that it reduced the "on my knees with a razor scraper" time did not hurt one bit.
Lol - yeah I've seen that done. I put a nickel in the rubber handle to keep the pipe from cutting through it.I threw a piece of rebar inside mine to prevent it from bending the pipe, I hardly ever use it though, hmmm what will I select?
