I have a buddy with an older festool. Might be the trion. The blade does not cut square to the base. So the bottom of the blade cuts farther than the top of the blade. Makes it a useless jigsaw for certain applications
I have a Bosch. It's good. I have a buddy with an older festool. Might be the trion. The blade does not cut square to the base. So the bottom of the blade cuts farther than the top of the blade. Makes it a useless jigsaw for certain applications
You say the bottom of the blade cuts farther? As in farther forward?
Yep. weird.
The carvex can back cut a scribe but only at the end of material. I have never used my jigsaw to do that as I used to use a angle grinder but now use my RAS. Much faster and more accurate to cut out scribes.
The trion can be had for a good price if you like that jigsaw. I never used it but never heard a bad thing said about it. The next best would be the older Bosch. The cordless Makita is a very nice jigsaw too.
EricBrancard said:I use a Makita angle grinder for scribing and coping some stuff. Will I be able to cope with an RAS?
