So, we rented a 28’ motor home for our trip from Oregon >Idaho>Montana>Wyoming>S Dakota>home
Literally the biggest piece of **** I have ever rented. 5 grand for 15 days. So glad wife now agrees we don’t ever want one. Stroke of genius on my part, renting vs buying used and reselling if needed. Cheap tuition.
The 2021 e450 chasis is great. 6 speed, 8 MPG. Easy transition from driving my box van. 18,xxx miles when we picked it up.
But everything by Jayco sucks.
Refrigerator doesn’t run when parked without shore power.
No Interior lights unless running or plugged in.
Generator doesn’t run unless ignition is on.
Silverware Drawer opens when cornering unless bungeed.
Two inset panels in cabinet detached, insufficient fasteners and adhesive.
Overpowered struts on overhead cabinets slam the ceiling when opened, light diffuser falls off.
Broken grates on plastic vent grilles.
LP heater doesn’t work. Blows ambient air when triggered. Doubt the AC works either.
Broken (fatigued) pin on the auto retracting step at the door. Easy fix.
Door doesn’t latch well. Daylight and road noise. Unlatched by itself twice at night.
Kitchen Window leaks when rain pours over it. Broken screen door handle, since it (used to) latches to the door and doesn’t disengage when the door is opened.
Fresh water supply leaks into the gray or black. 24 hours max of limited use for a 40(?) gallon tank.
Cosmetics? Glad you asked. Crooked refrigerator door. Crooked drawer front. Opened miter on overhead cabinet door.
Positively, the auto leveling jack system is pretty convenient and straightforward.
The LP stove/oven works fine.
I would be embarrassed or infuriated if I owned or managed Jayco.
For 150, you would hope an RV work as it should.
Can’t recommend at all. Anyone else’s experiences?
