jamb saw
17K views 44 replies 29 participants last post by  nymasterfloors
I'm getting ready to buy a new jamb saw for cutting door jambs in tile floor installations. Any suggestions on brands
Thanks,
Jerry
#14 ·
The Bosch 1640VSK fine cut saw that I have works great for undercutting wood door frames. With the flush cut blade, it’s faster and makes much cleaner, straighter cuts than my Rockwell Sonicrafter does for this type of work. I have even used the Bosch to flush cut underlayment to cabinet toe kicks on occasion.
If you buy the miter base for it, you can also use it as a mini miter saw to cut quarter round and baseboard. IMO, the only down side to it is that Bosch doesn’t have a metal cutting blade available for it.
http://www.amazon.com/Bosch-1640VS-...wer-Handsaw/dp/B00004SUP4/ref=sr_1_1?ie=UTF8&s=hi&qid=1295789293&sr=8-1-catcorr
#16 ·
loneframer said:
I really want to try one of these. Anyone have any experience with one?
http://www.amazon.com/Bosch-1640VS-Finecut-Power-Handsaw/dp/B00004SUP4
Yes-- I've had that saw for a number of years and love it as a jamb saw-- much faster & easier than the multimaster. Now with that said, if you had to choose between the two, go for the M.M. It's way more versatile--I don't know what I did before the multimaster I use it ALL the time now. If you've got the cash- buy both-- the blades for the Bosch jamb saw are way cheaper, last longer, and aren't as flimsy as the MM.
#19 · (Edited)
I have the Bosch Finecut and have used it a lot over the past 4 years. It works very well. The blades are not that expensive, ($15-ish). I usually add that cost to a few jobs so I can keep the blades sharp. Once they dull, they are worthless.
However, on a whim I bought one of the Dremel oscillating tools. It has been used on almost every job. I'm saving for a SuperCut!
The cost of the Craig is too high considering it only does one thing. Well, if you have the balls to cut the bottom of a door with it too, then it does 2 things. ;)
#20 ·
I guess I don't...or certainly wouldn't. Sadly, the Crain won't even reach into an inside corner to cut base. An oscillating saw will.
#33 ·
Here's the deal guys - if you do a lot of floors, get a Crain 820 and use it as your main jamb saw. If you have a whole house to do or even more than 2 sets of jambs to undercut, the Crain is a LOT faster than any oscillating tool or the Bosch. I own a Supercut. I also own 3 other Jamb saws. The blades for the Crain, costed out over their lifetime, are a helluva lot cheaper than the others. That coupled with the speed advantage and its a no-brainer...if all you are doing is a doorway or two then the other tools work great, but for 3 or more break out the tool that was made for the job :thumbsup:
I have the best of both worlds. When we start cutting jambs both saws are out. One guy goes through with the Crain and another guy follows with the Supercut cleaning up any inside corners or the small pieces close to an existing floor that cant be reached with the Crain. It is a quick effective method that works. Two guys can undercut a whole house in 10 minutes. The Crain can also undercut stone fireplace hearths with a diamond blade.
#37 ·
You have obviously been observing hacks :laughing: Seriously though, that's not an issue unless you are too cheap to buy a new blade every 4 or 5 jobs. I used to work with a guy that wouldn't change them until the saw set off every smoke detector in the neighborhood.
The blades are $22. If you build a consumables charge into every job (which a pro should be doing) there is no excuse.
