Temp Walls....
Burried electrical/plumbing could be a deal breaker for flush.
Instead of cutting studs to length,...........
Neo-what's are you referring to as an A frame? I will have to set posts down to the footer first an ensure jacking is pushing down the post, but I'm still thinking of how to do this (with ease). I have a concern of pushing up the joists and the ends (which have pulled down b/c of the curvature of the beam) not 'floating' back up the top plates but pushing against them. ..............
I'm curious Gene if it would be fesable if in place of building 2 temp walls that he uses adjustable jackstands instead?(depending on rental costs etc) then instead of tearing down the "walls" after, he can just pop them out. Years ago my parents had that prob and if I remember corectly(of course I'm trying to remember through my "chemical"/alchohol hase of the 80's:whistling) the contractors used them in our finished basement to adress the sag problem of the floor joists for the ground floor. I've also seen simular jackstands used to support the plywood forms for slab pours on commercial sites.For flush beam/temp wall either side of cut
On several occcasions for one company I worked for we had to crawl under off grade laundrymats in apartment complexes. We took a pair of 12 ton bottle jacks jacked the sag out and then sisterd a 2"X12" the length of pylon to pylon to each floor joist. So since it was a different senario we couldn't get much under the confined area and I'm curious about the jackstand application.
I await your knowledgeable reply kind sir.:notworthy
Dude..........:no:A steel I-beam I like to use
Weight per ft depth width flange thickness web thickness
14lbs -------11 7/8 --4" ---------1/4 ----------3/16
Will hold a lot of weight for its relative lightness, cheap too compared to a lam
Depends on how its loaded of course, but it is a strong beam. Anyone doing something involving support is going to have to run some numbers. Its not a specific recommendation, just an idea, throwing it out there. Is that better grumpy? :notworthyDude..........:no:
I think we're obligated (I know I am) to refrain from making specific recommendations, that ANYONE who reads may construe as fact.
What's a 'lot' of weight ?? 'Shed roof' or Hyatt Skywalk?
Without inspecting a situation, no one can recommend anything..
From his description of the damage (water and termite), I think he has bigger problems, but I Don't Know:thumbsup:
[email protected] I'm grumpy lately:laughing::laughing::laughing:
Someone told you about that, right? :laughing:........
Oh and don't forget to put your header materials between the temp walls first.:shutup:
