I made a jig to make cutting jack miters easy. Jack miter cuts can be done with power tools... but the head casing miter cut made with a power miter saw leaves a fair bit of hand saw work to get into the inside corner (like finishing stair stringer cuts by hand).
The jig I made holds the casing on edge with just the profiled portion to be mitered showing. This is similar to the jigs the old timers used to cut jack miters... I just added the hand miter box. This lets you cut the miter with a hand saw very precisely and quicker than cutting with a power miter saw and switching to a hand saw to finish. This only makes sense it you regularly cut jack miters (of course if you have one you might regularly cut jack miters
) )... but here it is anywho:
