1 - 17 of 17 Posts
Welcome to CT. Just a heads up, you will get great advice here if you follow the protocol of the forum. Please fill out your profile more thoroughly including your area, as well as do an intro in the introduction section.:thumbsup:
Well, if no flex j is the order of the day i can only see 2 viable options:
1. Order a completely new window with a built in J channel track/brickmold option then you dont have a thing to worry about
or
2. Custom make some trim/brickmold out of Azek and leave a channel for the siding to slide in behind.
Discussion Starter · #7 · (Edited)
or
azek isn't av. in Cheyenne and i already tried ton talk him in to new windows it was a no go
I've made more than one trip out of town to pick up materials not commonly stocked locally. It'd be worth a few phone calls to find a vendor that carries it so you could at least price it, along with windsheild time to grab it, and give the HO the option. Driving a few hours never scared me since i get paid regardless:thumbsup:
if vinyl siding is avalible im sure you can get pvc trim just maybe a different brand than azek
you could route something from pvc but your going to have to make it wider and make sure you manage flashing properly
if you don't want it wider than the j face well.....
topsail's trimcat
push them on the idea of the pvc or at least make them understand that a new window is the only way with it j'd out or can you take the existing window and cut out the section of plastic which would otherwise be open for siding.
and flash it with 3m flex flash, same idea as vycor or bluskin only its designed specifically to work in arches
Reactions: randy franks
3m? or tyvek flex wrap? great stuff but about 175 bucks a roll
i use it for sill flashing mostly
topsail's trimcat
yah, the 3m is pricey, try blue skin and do it in a series of peices and make sure to use lots of primer then maybe seal the seams with primer. but if the 3m will work better as one peice than a series of em its money well spent. just factor that into the price or a percent of the roll then use it on the next one
flex-J around round window
we just cap over our flex-j with a window cap like the cap we use on the straight window trim. If capping a half round window is not up your alley, the web has products to make it easier. I have seen half round window trim caps for vinyl siding and we use them. It keeps the customers happy. But either way, good luck.
1 - 17 of 17 Posts
