nevermind i figured it out on my own like a big boy.
hahahaFirst problem is you are trying to place a switch cover on a receptacle.
depends how far it is but you can move the switch or recept out by placing bushings behind the ears at the screws. I'm betting this is what you did. It's rocket science!
I hope the solution was simple and cheap like this and some longer screws:
http://www.aifittings.com/whnew120.htm
oh i get it i see what you did there. very clever :laughing:First problem is you are trying to place a switch cover on a receptacle.
Are you hanging drywall with the receptacles and switches already installed?the solution was i loosened up the screws holding the outlet on the box, so everything is just dandy now. have a few more pieces to hang then its time for joint compound!
???the solution was i loosened up the screws holding the outlet on the box, so everything is just dandy now. have a few more pieces to hang then its time for joint compound!
ERICO offers the CADDY Device Leveler and Retainer.Features
Applications
- Prevents broken cover plates
- Stops device from being pushed back in wall
- Makes floating device rigid
Ideal for oversize dry wall openings, tile and panel walls.
I would take this to mean if it measures 1/4" than it is against code...(including a measurement of) 1/4" and more would require you to use one of those devices Celtic owns stock in because of all the panelling jobs he takes on.314.20 requires boxes NOT be set back 1/4" or more.
314.21 takes it down to 1/8"I would take this to mean if it measures 1/4" than it is against code...(including a measurement of) 1/4" and more would require you to use one of those devices ...
:thumbup:Celtic owns stock in because of all the panelling jobs he takes on.
yeah. i think the electrician though i was going to use 3/8ths instead of 1/2.Are you hanging drywall with the receptacles and switches already installed?
