Dealing with low basement height clearances is a common problem for many remodelers. Aside from the occasional beams, HVAC supplies and returns are often the biggest obstical. Traditionally, we've minimized the ductwork's intrusion by using shallower and wider ducts and creating ceiling soffits.
What would be the problem with constructing the Supply line so that is has a short down-vent immediately leaving the furnace and running supply along the FLOOR hiding ducts under window seats, etc.
Seems like it would create some ininital resistance making blower work harder and consuming more power - but if sealed well wouldn't this function normally?
