on a different but same note, why do some old timers use black paper on walls instead of Tyvek?
Because some of us "old timers" started using felt, made the switch to Tyvek and after several years, were not impressed.
Felt has some properties that plastics don't and that's why I prefer it.
http://bct.eco.umass.edu/publicatio...u/publications/by-title/housewraps-felt-paper-and-weather-penetration-barriers/
from the link
Housewrap or Felt?
Based on our testing, if I were buying a housewrap today, I would choose either Tyvek or R-Wrap, because they display the best water resistance. But so far, I’ve avoided the million dollar question – housewrap or felt? The truth is, there’s not million dollar answer. In general, I don’t think it matters a whole lot. If you get the flashing details right, and are careful installing the building paper, you will prevent 99% of the moisture problems caused by wind-driven rain and snow. Either product, housewrap or felt, will provide an adequate secondary drainage plane. And either product is permeable enough to allow interior moisture to escape.
As it happens, I have felt paper on my own home, and if I could choose between felt and housewrap and do it over again, I’d still choose felt. That’s because I believe that under certain circumstances, felt outperforms housewrap. For example, an ice dam or roof leak may allow liquid water to get behind the felt or housewrap. It’s also possible for the sun’s heat to drive water vapor through the housewrap from the outside, where it can condense on the sheathing. In either of these cases, you now have liquid water on the wrong side of the wrap. Under these conditions, the liquid water would be trapped by the housewrap, which is permeable only to water vapor. Felt, on the other hand, will absorb the water, and more quickly dry to the outside.
