1 - 12 of 12 Posts
I have a customer who need a couple of 6' x 6" hollow bumper post installed.
I plan on drilling out a 10" hole. Then digging it down
about 2' in the ground. And cement it in place,then filling
The hollow post with cement. This is a inside job. My question is
do you think digging it down 2' then cement it place. Will
be sturdy enough to handle a bump hear and there by a hi lo.
Thanks in advance
Yes, its a 8" concrete floor. I'm rebuilding the the block wall that was hit.
So he wants me to put in some post
What do you think the point of impact will be it someone hits a post?
If it is 3 to 4 feet high I would go a foot deeper with the posts.
Don't forget the pretty little round cement caps.
Install bollards or guard rails bolted to the floor with 3/4" Redheads. You won't have any problem. I've installed several for the purpose you mention. Forget all that digging, concrete and painting.
http://www.grainger.com/Grainger/gu...nt/material-handling/ecatalog/N-9rd?op=search
Whoops.....6' high bollards ? Get a fabricating shop to make up a steel column with a base plate with holes for 3/4" bolts. You can fill or partially fill with concrete if you like.
I'm thinking the covers would minimize the paint damage to the machines, no?
MHIC licensed contractor
I used to get thick walled tubing from a pipe supplier, 8" diameter. Most of the post I would fill with compacted dry sand, and the top would get a concrete cap.
1 - 12 of 12 Posts
