U
Unregistered
·Guest
(1.) I am ready to install Wilsonart Estate Plus tiles in my kitchen, dinette area and utility room. Unfortunately, I failed to order the Wilsonart glue that I now know is required on at least the first row of tiles. Due to a weeks delay when some of my items were lost in transit, I have exceeded the time allocated to this project and do not want to loose this weekend waiting for a shipment of the glue. I found a glue at Loews that I wonder if it will work as well as Wilsonart's. It is Precision Components Flooring Installation Glue, "Works on All Brands of Laminate and Wood Flooring, Water based PVA adhesive, D-3 Certified, Resists Moisture".
Since this seems to be a relatively new product line with Wilsonart, I wonder if their branded glue is in fact required?
(2) The installation recommendations are to "install from left to right". Since the Wilsonart locks from the horizontal position, is there any reason to not put a row down the centerline and work in both directions from that? I have quite a few cabinets and short walls to work around and it seems it would be easier to start in the middle.
Thanks for any quick replies.
