How can I tell if a house will handle baseboard heat with 100 amp service, how many amps is a typical baseboard and is it possible to put 2 on 1 breaker
Do a load calculation per Art. 220.How can I tell if a house will handle baseboard heat with 100 amp service,
Depends on the watts and voltage. Usually a function of length.how many amps is a typical baseboard
Yes.and is it possible to put 2 on 1 breaker
Well, duh, of course they want to put in central heat, they are HVAC workers after all. :blink: You should be asking your HVAC crew about central air, and your electrician about electric baseboard heat. :thumbsup: Also, ask a plumber about a new hydronic heat system because that's the most efficient heating system.6' baseboard heat 220V is 1500 watts , a 20amp breaker can carry 2? I am having conflicting reports on whether this house panel box will allow for baseboard, had electrician say yes and hvac say no(they also want to put in central heat)
MDF or finger jointed pine?How can I tell if a house will handle baseboard heat with 100 amp service, how many amps is a typical baseboard and is it possible to put 2 on 1 breaker
