Inspector says Vinyl ledger flashing is a no-go
9.2K views 9 replies 8 participants last post by  rblakes1
Hey all,
Ever since the changeover of treated wood to non-arsenic-containing formulations, I have been installing vinyl flashing behind my ledgers (as well as using vinyl Z flashing at the top of the ledger). I submitted a plan to a local building code official citing such flashing (of course, the homeowner designed the deck!!!). He told me in his 25 years of being an inspector, he has never heard of vinyl flashing be approved for deck ledgers. Telling him it has been accepted by every other code jurisdiction for the last ~1000 decks I have done didn't seem to convince him or make him happy :)
Section R703.4 of the 2021 IRC states (in part), "Approved corrosion-resistant flashing shall be applied shingle-fashion in a manner to prevent entry of water into the wall cavity or penetration of water to the building structural framing components." Generally, "approved" means acceptable to the building code official.
Here is what he replied to me, "2021 International Residential Code, NJ Edition, section R507.2.4, Flashing, is pretty liberal on what materials can be utilized. Specifically, “Flashing shall be corrosion-resistant metal of nominal thickness not less than 0.019 inch (0.48mm) or approved non-metallic material that is compatible with the substrate of the structure and the decking materials.”
It is apparent to me that vinyl is compatible with both the substrate AND the decking. But, he is asking for proof from an "accepted testing agency" that vinyl flashing is acceptable. I have scoured the AAMA, among other building sites to find this common sense "approval." So far, I have found the Florida Building Commission specifically lists vinyl as an approved flashing.
Does anyone else have any leads on other sources that list vinyl as an approved flashing?
Yeah, I know I can easily change to that ridiculously heavy .019" old-school galvanized roof flashing if I have to... but I am a stubborn old mule!!
Happy Weekend!
Jeff
#4 ·
Tell him to read the code and pay attention
R507.2.4 Flashing. Flashing shall be corrosion-resistant
mm) or approved nonmetallic material that is compatible
Show him the manufacturer specs which specify that Vinyl Roll Flashing can be used much like aluminum, steel, or copper flashing and is completely corrosion-resistant and Intended for use with pressure-treated lumber
What town this is in Jersey, wouldn't be Lawrenceville? That building inspector there is an A-hole with his own agenda.
#5 ·
Unfortunately, "approved" means by the Chief Building Official - if that is said individual life gets tough. If said individual is not the CBO float it past him. I would see if there is an ICC ESS report, ICC interruption out there. Easiest is APA Woods A530 where it specifically lists vinyl as a flashing material.
This post has been deleted
