It has probably been five years since I have tried this trick.
I am putting some boards on the face of my gas fireplace. This fire place sits in the corner of the room, and the base is on. so on the last board on either side I need a 3 1/2" slit at a 45 to slide over the base. No problem right?
Yes big problem, I am tired, and almost done. last cut will not go thru the table saw forward. now I carry two circular saws in my truck just for this problem, but i am to fn lazy to walk 200 feet to get the other saw.
Yes you guessed it I am going to run it thru the table saw backwards.
I will save at least 2 minutes here.
Now I have done this a number of times since the beginnining of my career with almost no succes.
Tonight will be diffrent I am much older and wiser.
You guessed it I made it about half way thru the cut and boom right into the side of the patio door. I have at least learned to stand off to side.
Dented the casing, the door, and cracked the vinyl.
Good thig I did not waste all that time walking up to my truck, and getting the other saw:no:
