1 - 20 of 25 Posts
I am wondering I spilt oil based paint on unfinished oak stairs. I cleaned it with paint thinner but the stairs are now dirty, and soiled. What can I do to clean them before they are stained? Any advice would help
· Maker of fine kindling
They are toast.
Open grain wood and all that thinned out paint in the pores, not even worth trying to sand that out.
You could spill paint on the whole thing and clean up the best you can then sand the best you can. Then the whole set will look the same.
You could paint the whole set.
Tough break:no:
· Contractor of the Month
Really, you have no idea how to use a sander and fix that?
I did a foolish move like that when I was younger, luckily it wasn't someone else's wood and onece you sop that thinner on it your in for alot of sanding!!
Can I suggest the sander he use?
Can I assume its best used with a really expensive shop vac called a "Dust Extraction System"?
· Administrator
Sawdust follows Me Everywhere
Wrong picture Gus, he needs the Elton glasses I made for him. :laughing:
sweep a bunch of dust over it and let the next guy worry about it! lol I too feel if you choose to sand it out you may have to sand the tread down to nothing. Gus's idea about staining/cleaning up the rest may be a viable option. What about just replacing a few treads?
· I like Green things
Am I getting warm?
You can't get very close to the riser with these.
And what if there is a cove under the tread?
Friggin nightmare.
Actually Gus, if you put this on it, came in the Systainer, you can sand right up to adjacent objects, risers, and leave a nice clean line.
1 - 20 of 25 Posts
