21 - 40 of 44 Posts
Discussion starter · #24 ·
I didn't see how you were getting a taper. I assume you aren't juat eyeballing them.
The centers aren't the same height. The blank where the crank is has it's center 1/4" lower than the other side creating the taper.
Discussion starter · #25 ·
Lot of ingenuity there Leo!
It's either that or an attack of brain master-bat'n...
Maybe next time...
Use 5/8, or 3/4 roundover bit, & do taper side to side, instead of top to bottom?
The cuts would blend in nicely tjat way.
It's just cool when someone actually makes something.
Not assembled it, installed it or bought it, he made it out of a stick of wood with the tools he had.
Well done.
Reactions: 530Foreman
Discussion starter · #30 ·
Maybe next time...
What do you mean side to side?
Discussion starter · #31 ·
Pretty badass Leo.
Do tell where ya got the rails & bearings. I think that would work well for flattening a slab.
I've had them for a loooong time. This is the 3rd machine I've made from them. I made a router duplicator 1st, then that laid stagnant for quite some time after I did the 30 or so rosettes I needed to make (4 different kinds). Then a slotter for Euro cabinets and now this "lathe"
I think the place was called Specialty Motion Inc. But I've searched for them and don't think they're around anymore. Lots of places to get linear bearings and rails.
Discussion starter · #32 ·
Finished up another 35 spindles and then put the tenon on the large end. Did it in a 2 step process because I don't trust doing it in one pass.
I did a setup on the tablesaw with some stops the put the spindle right where it needed to be both near the fence and at the edge of the tablesaw to keep the spindle square and level (because of the taper)
1st pass was just a thin kerf saw cut and the 2nd pass was with a dado blade. I did the saw cut to make a clean kerf and then the dado was kept away from the shoulder so it wouldn't chip out.
Discussion starter · #33 ·
A cool shot of the spindle in the middle of the cut
Discussion starter · #38 ·
My Shopsmith lathe only does 34 inches Leo ,but you’re more than welcome to use it anytime.
I think it'd be harder to do on a lathe. You'd have to think. This way the machine automatically spits out the right size.
Discussion starter · #40 ·
If I had 36" to work with maybe. I'd have to figure out a way to swing the big into the wood too.
21 - 40 of 44 Posts
