Wanted to get someone with a lathe to do this work but the 2 guys I knew were 6 weeks out. I had some linear rails and pillow block bearings that I bought a while ago for a router duplicator and then I converted it into a slot maker for Euro cabinets and now I turned it into a lathe.
Made a video of me making a spindle. It's less than 8 minutes and it shows me going through the process of making a spindle for stair railings. Wish the camera was slightly more to the left. That's where the vice grips are that I use as a handle to spin the blank.
0-3:42 is putting the blank in and roughing it out
3:42-6:00 is readjusting the router setup and doing the final milling pass
6:00-end is sanding and removing the spindle.
