1 - 11 of 11 Posts
Any one have data on how much lineal feet one gets breaking concrete footings with a hyd hammer.
I mean the number of feet an hour.
Footing is one foot wide three feet tall; do not know if it has rebar in it.
Mini Excavator 12,000 machine Kubota 161.
Rental hammer looking at is Atlas Copco SBU220 weights 500 lbs. with
Energy Impact Class 550 (ft-lbs).
Could use the expanding grout to break it up, drill it pour in the grout let it set, but I think the hammer would be a lot faster.
Get a larger machine and just dig it out. Breaking it out would work. But very slow. It would be much easier to excavate it then break it on the 12" dimension. With a larger machine you can break up the pieces much faster by lifting and dropping the pieces
It will be difficult to break concrete 12" wide for the full depth. If you can excavate next to the footing and break horizontal would have better success but it is hard on the breaker and machine.
Seems like it would take a ton of time to remove with a mini. Can you get a 160 or 200 size hoe just to get it to a pile then you could even use a skid steer with hammer to break it down. If I put one of our 200's on it I think you could at least get it down in bigger chunks to another machine.
Vagitarian
No data, but if I were bidding it, I would shoot from the hip. How many linear feet are we talking about ? If is it a large quanity, I would look at getting a bigger machine. The cost for rental is not much more and the speed of breaking will be 10 fold. We have a NPK hammer on our Cat 315. It is a 3,000 ft/lb hammer and we do alot of breaking with it. We also have a hammer our on Case 590 backhoe which is about the size of the one you are looking at renting. The bigger hammer will simply destroy the smaller hammer in production. When hammering, bigger is better.
1 - 11 of 11 Posts
