Humidifier
5730 Views 12 Replies 5 Participants Last post by  beenthere
I installed a General Aire 1042 for a customer in a 2000 sq' house. On a high velocity system. The system is wired properly cause the solenoid opens and water flows on a call for humidity. The customer has a hygrometer upstairs and registers 27% relative humidity. We can't get the RH up any higher is the problem. New house. New air handler. High Velocity system works well enough according to the customer. Humidifier is attached to the return with a 2"insulated bypass from the 8" supply on top of the air handler. Water supply was recently changed to the hot side hoping that would help with no success. The side of the humidifier is a 6" opening that I've installed a 6"cap and attached the 2" bypass as per the air handlers manufacturers instructions. Yes, the damper is open. Has anyone got any suggestions?
1 - 13 of 13 Posts
I don't think that humidifier is the best fit for a high velocity system
What humidifier would you recommend? Yes, 2" bypass. It's for a high velocity air handler. 2" is recommended by the air handlers manufacturer.
When you connected it to the hot water line. Was this the how water pipe at the water heater. Or just one that was near the humidifier? Needs to be at the water heater. Can't be bigger then 1/4" either, and you may need to insulate it. Have the water temp set up to 140°F.
What is the air handlers heat source. Is it a hydrocoil, electric strip? Is the bypass before or after the heat source.
Probably should have ran a 6" pipe off the humidifier for about 2 foot, then attached the 2" line. So more of the humidifiers pad got air going across it.
Does anyone make single room humidifiers that mount in walls or in ducts, for local control? I could use one myself.
Aprialiare makes one that mounts in a closet, and another that mounts through the floor. Both are designed to do a whole house though.
So you will get short-cycling if used for just one room?
Probably.
Maybe. I didn't bother to look at the search results.
Those are all for ducts systems.
If you just want one room. You will nee a portable room humidifier.
1 - 13 of 13 Posts
