1 - 3 of 3 Posts
DGR,IABD
That sounds similar to the "desert air" systems that we install for indoor pool areas. They work great. If you have such a high normal moisture load in your home that you would consider installing a humidex system to lower the humidity in the entire home, the better move might be to find the source of the objectionable moisture.
What do you consider a "high" moisture load indoor for summer?
1 - 3 of 3 Posts
