How well does Mapei mortar work on installing Ditra system over OSB?
29K views 15 replies 6 participants last post by  JazMan
#1 · (Edited by Moderator)
#10 ·
Hey guys, did you miss that he's not installing tiles over the OSB, he's installing Ditra to the OSB, then tiles.
Any modified thin set will work for the purpose of installing Ditra to an OSB subfloor.
Jaz
#11 · (Edited)
Why does no manufacturer specify OSB as an approved surface to use thinset to?
Let's face it, a majority of installs over OSB are most likely done with CBU. Why wouldn't a manufacturer recommend their thinset in that scenario? Hell, after the CBU is fully supported and mechanically fixed, who cares if the bond breaks? Yet, Mapei says no to using thinset over OSB.
#13 ·
Angus,
You're misapplying the manufacturers' recommendations. Tiles, therefore thin set, can not be applied to OSB along with several other substrates as we know. That is different from applying thin set to install a CBU or Ditra. OSB can be a bit unstable, that is why it's not an approved underlayment. Ditra's characteristics more than makes up for this instability. Modified thin set bonds very well to OSB.
Oppie's deal is a completely different situation. As I recall the Ditra was installed with unmodified mortar to either plywood or OSB. Never had a chance. Someone didn't read the directions.
Jaz
#16 ·
Hi Dan,
I know you were not implying that your rip out was done by someone following any directions. I posted because some seem to think that OSB means it has to be covered with plywood underlayment. We know it doesn't. I believe you've know that for many years.
Jaz
