1 - 20 of 50 Posts
· Tech Geek
I see 5.
- Drywall screw in the bottom because the box is too far back in the drywall.
- Wires twisted the wrong way on the screw
- sheathing isn't stripped back far enough in the box
- no box extender
- I'll bet the ground isn't tied to the box.
Did I miss any?
· I own stock in FotoMat!
I will post my resonse after the following advertisment:
Other than a poor production where the audio does not match the video:
1. Using a volt tick to test for power
2. Old recep installed with drywall screws.
3. Grounding conductor installed wrong direction.
4. I don't see any neutrals in the box. Only grounded ones.
5. Waaaaay too much insulation stripped off the top white wire.
6. What the he11 is a 'positive' wire?
7. 'Positive' wires installed wrong direction.
8. 'Positive' conductors have too much insulation stripped off.
9. Box is recessed too far into wall.
10. Yappermouth uses too much slang and talks like a street thug.
11. "Flat head, most likely"...... what else is there with cover plates?
12. Final test done with a volt tick. Again, totally amatuerish.
13. Grounded side of recep reads as energized with Timmy Tattoo's tester.... reverse polarity!
14. Never mind about telling folk about turning the power off..... if this had been a loose connection issue, li'l ol' Timmy would be convulsing on the floor.
15. Oh, and don't bother to mention turning the power back on.
16. What about testing it for proper voltage, as well as grounding?
"Grounded?" :whistling
Yes. That receptacle has three types of conductors tied to it........ ungrounded, grounded and grounding.
He stuck his little fancy-dancy tester into the grounded slot, and it indicated an energized conductor.
· Thom
This is not a code/safety issue, just a question. Is putting receptacles up mid wall height normal anywhere (excepting countertops of course)?
Sometimes it's common. ADA may require it. I also install them at that height for people in wheelchairs. Other times, it's because they're in an area with lots of children and the owners want all the receps up high.
I also install them up high like that in unfinished areas like basements, as well as garages. Otherwise, they tend to get covered up. There may well be a planned entertainment center going in that location.
As long as they're below 5'-6", they're legal. 210.52(4).
· Baltimore Electrician
"Normal"?
Well, I have never heard of it being common practice, if that is what you mean. I have seen them anywhere from 10" to bottom, to 24" to center. Usually 15-18" to center is what I see.
For residential, the required outlets must be within 5' 6" of the floor.
In these areas, I also put receptacles up high - 44" or so.
I was thinking of habitable rooms with my previous post.
Discussion Starter · #20 ·
Boxes
I might have to red tag you cause your a little shy of the 3'x3'x6' rule. Seriously, is that video for real??? After the second time I watched it I'm wondering if it's Batik or some other joker? That can't be for real could it?
1 - 20 of 50 Posts
