1 - 6 of 6 Posts
Hey guy. I'm a GC. Not a painter, but have done quite a lot. I do own a airless sprayer.
I do a lot of rehabs and always come across old, dingy, varnished trim around windows that need to be painted white.
Here's the problem. Even after spraying on primer and 2 coats of paint. There is still some bleeding. I'm using paint and primer In one (grand distinction from menards, 30 dollars a gallon) paint.
What's it bleeding? nicotine? tannin?
If there is something inherent to the wood itself, may take a slow dry primer.
- Agree with our company, that it must be done as a seperate stage.
If it's clean, it shouldn't be a problem. I understand you're in a production setting and may not be able to go through 4 or 5 steps.
At the very least, get someone to go around with a good grease cutting cleaner. Basic dishsoap will work, but tsp is better as you can adjust the strength. Try that, otherwise, you'll have to clean and scuff first.
Keep a can of oil base kilz on hand and some foam brushes on a stick for spot priming.
1 - 6 of 6 Posts
