How to paint a non-paintable silicone I have done the same mistake and didn't realize until i try to paint. But a little of brain movement give me a bright idea, and i did paint successfully all trims around bath tub, and paint stays on it okay. Just in case you did same mistake that i did, used non paintable silicone and try to paint. Don't worry, you will paint too, and paint will stay on it. You don't need to scrape old silicone or use paintable silicone over non paintable silicone, or any thinner. ALL YOU NEED! IT'S A REGULAR HAIR DRYER BLOWER. PUTT THEM ON HIGH HEAT AND GO! First apply a thick and even layer of paint on surface you painting, and apply heat before paint gets off of the silicone, and there you go, the way to SUCCESS!!! Or try to paint and use at the same time hair dryer. Hold hair dryer about 10 inches away, AND ON HIGH HEAT. But do not over paint, other way you'll have to scrape the paint, and make it even worse. You can re-paint with roller when it's completely dry, but the first time you have to paint with paint brush. And good luck!!! And if you have any questions, ask at. bestjetpilot@hotmail.com
Added by: Aleksandr Dovgalets.
