How to lay brick
6.1K views 21 replies 11 participants last post by  fjn
#9 ·
I have never read The Quest Of The One Best Way however,i agree wholeheartedly Frank B. Gilbreth's book Masonry Systems is an excellent read. Like all books,there will be concepts we concur with and those we do not. Over all,the book has many more concepts that would be helpful.
One of my favorite chapters is chapter #1. In that first chapter is a nuance that i feel has not been taught to new bricklayers wanting to enter the trade. For that matter,some long time masons have not ever learned it. That concept is the SET IN or sometimes called Roll ,in facing off bricks laid.
This nuance is best described on pages #3 and #4 of the first chapter. here is the quote straight from the book. "While the amount of overhang and set-in of each course is slight,it is enough to show very plainly. If you sight down the face of the wall you will see nothing but mortar. If you sight up the wall you will see nothing but brick".
I wish the young fellas that want to be hired had a grasp of that concept,it seems so basic. That is why i want planks jacked when it is time,you cannot "sight " the bricks properly laying brick much higher than chest high.
The aforementioned book can be read here.http://books.google.com/books?id=if...NAAAAMAAJ&printsec=frontcover&source=gbs_ge_summary_r&cad=0#v=onepage&q&f=false
Scroll to pages #3 and #4 for a visual depiction.
Great tread, thank you for starting it !
#19 · (Edited)
25. Some brick are wider upon one side than the other, due to the slight batter of the vertical surfaces of the molds to permit the removal of the brick. In this case, the brick may be laid flat, if the wider side is laid at the top, automatically producing the desired result. Other brick have both the face and the cull surfaces parallel but sloping at a slight angle
from the sides. The brick may be laid flat but with the facc so placed that the upper edge projects beyond the lower edge.
26. Some bricklayers claim that they can tell by the feel of the brick the proper side to select for the top and turn the brick to the right position while it is in motion from the scaffold to the wall, doing this almost unconsciously from practice.
I thought this was rolling the wall
No wait, here it is
23. Roll.-As the top edge of the brick is always laid to the line, it is this edge which should be the most prominent upon the face of the wall so that one looking up from the ground will see the upper edges projecting slightly beyond the lower edges of the brick, forming a series of parallel lines for each course. This tends to hide any irregularities on the facf of the brick, giving the entire wall the appearance of careful and accurate workmanship. In order to accomplish this, it is necessary to give the brick a slight "roll," that is, to slope the brick so as to bring the bottom edge slightly in from the line of the wall.
#22 ·
For all practicalities regarding this discussion the U.S. has three nomenclatures for brick,they are FBA,FBS,FBX. There are others but they do not pertain to topic. The vast majority of brick used in my local fall into the FBS,FBA class. The FBX brick are used most often on commercial,institutional and religious buildings. Those brick have the most exacting tolerances. Irregardless as to how the brick was formed,wether it was extruded or wood molded,there is a certain amount of distortion in the brick. Again,FBX brick is the least prone to this distortion. That distortion needs to be "adjusted " for,that is what the author presented on pages #3 and #4 in Gilbreth's book. Attached please find the B.I.A. tech note that eloborates on this topic. If you scroll down to TABLE #7 DISTORTION TOLORANCES it is explained there. http://www.gobrick.com/Portals/25/docs/Technical Notes/TN9A.pdf
